Talent LP64LED-FLAT Slim PAR 64 LED Light Fixture DMX Controllable with Remote 181 LEDsTalent Sound & Lighting's LP64LED-FLAT fixture is operable as a stand-alone device that runs on pre-programmed routines or sound activation, in master/slave mode with other LP64LED-FLATs, or via a user-supplied external DMX512 controller. In DMX mode it is configurable to be controlled by 3, 5, or 7 channels.
It's also possible to link as many as sixteen LP64LED-FLAT fixtures and operate them without a controller. In Master/Slave mode, the first fixture will control the others to give an automatic, sound activated, synchronized light show. This function is good for when you want an instant performance. The first, or master, fixture's DMX input will have nothing connected to it. Its output connects to the remaining fixtures, which will be set in slave mode automatically. For completely hands-free operation, simply set the LP64LED-FLAT to sound activation mode and let music control the show automatically.
The LP64LED-FLAT's active components are housed in a compact, all-metal enclosure that features a dual yoke for hanging the fixture or standing it on any flat surface. An AC power input cable is attached for convenience, and on-fixture programming is accomplished via pushbuttons and a digital display. Male and female 3-pin XLR connectors are furnished for DMX data input and loop-through. A fully featured remote control with an effective range of 10 meters is also included.
Specifications: • LEDs: 181 Ultra Bright 10 mm (Red: 49, Green: 72, Blue: 60) • DMX channels: 3/5/7 selectable via digital display • Modes: Auto, sound active, DMX, master/slave • Beam angle: 20° • Control input: DMX 3-pin XLR male and female • Power input: 90~250 VAC, 50-60 Hz • Power consumption: 20 watts • Dimensions: 10.1" x 10.25" x 3" deep • Weight: 3.52 lbs.
