  • Quam SYSTEM 7DT 4" Drive-Thru Menu Board Speaker Black
CLEARANCE Quam SYSTEM 7DT 4" Drive-Thru Menu Board Speaker Black
3 Questions, 9 Answers or
Quam
Part #244-3062
Quam
Part #244-3062
Model: SYSTEM 7DT
The SYSTEM 7DT by Quam is a complete menu board loudspeaker assembly with 4" O.D. loudspeaker.
  • 4" Drive-Thru menu board speaker
  • For indoor or protected outdoor environments
  • Program material: Signal tones and voice
  • Made in Chicago, USA
Quam's SYSTEM 7DT drive-thru menu board speaker has a 4" O.D. loudspeaker, 22 gauge steel baffle and enclosure, and a nominal impedance of 8 ohms. Baffle and enclosure finish is a black baked epoxy hybrid. Intended use in an indoor or protected outdoor environment, mounted on a vertical surface for signal tones and voice. Made in Chicago, USA.
Specifications: • Average sensitivity: 91 dB 1W/1m • Power rating: 10 watts RMS • Calculated output: 101 dB SPL, 4W/1m • Frequency response: 130 Hz - 9 kHz • Nominal coverage angle: 90° included angle, -6 dB/ 2 kHz, half space • Audio connection: 15" color-coded pigtails, pre-cut.
BrandQuam
ModelSYSTEM 7DT
Part Number244-3062
UPC844632097140
Weight1.95
ColorBlack
ConfigurationFull-range
Input Rating8 ohm
Woofer Diameter4"
Special FeaturesIndoor / Outdoor
MONSTER DEAL
OF THE WEEK
$23.98 EACH
SAVE 20%
Lepai LP‑2020BT Bluetooth Hi-Fi Audio Mini Class D Stereo Amplifier FM Media with Power Supply
