  • Pioneer TS-W254R 10" 1100W Mobile Audio Subwoofer 4 Ohm
CLEARANCE Pioneer TS-W254R 10" 1100W Mobile Audio Subwoofer 4 Ohm
3 Questions, 3 Answers or
Pioneer Electronics
Part #267-2500
Pioneer Electronics
Part #267-2500
Model: TS-W254R
Pioneer's TS-W254R 10" subwoofer is designed for maximum bass without taking a large bite out of your budget.
  • IMPP cone resists deformation during heavy bass passages
  • 6-layer voice coil for high power handling
  • Vented pole piece with extended yoke for reduced power compression and longer stroke
Pioneer's TS-W254R subwoofer features an all-new design and look. All areas of performance have been increased over Pioneer's prior generation of subwoofers. Its six-layer voice coil allows for 250 watts RMS power handling (1,100 watts max) to really get things cranking on your daily commute. Purpose-built to work well in sealed and ported enclosures. A large Strontium magnet create a high power motor assembly for a high sensitivity of 93 dB @ 1W/1m,.
IMPP Composite Seamless Cone
An extremely durable, yet lightweight cone is vital to prevent a cone failure at high sound pressure levels. Pioneer's new IMPP composite seamless cone meets this need perfectly while delivering accurate yet powerful bass and increasing sensitivity.
Treated Foam Surround
The treated foam surround dramatically improves durability and lightness for superior response, especially at louder volumes. It also prevents against fatigue created by the extreme temperature swings present in car audio environments.
Vented Pole Piece
Pioneer designed the TS-W254R with a vented pole piece to promote movement of air within the subwoofer. The vent is smoothly channeled for optimal ventilation to ensure a quick response and clear reproduction of bass, reducing the compression that results from trapped air during heavy bass passages.
Includes six 1-1/8" self-tapping screws.
BrandPioneer Electronics
ModelTS-W254R
Part Number267-2500
UPC884938143493
Weight8.55
Nominal Diameter10"
Bolt Circle Diameter10.1875
Power Handling (RMS)250 Watts
Power Handling (MAX)1100 Watts
Frequency Response20 to 220Hz
Sensitivity93dB 2.83V/1m
Resonant Frequency (Fs)33.5Hz
DC Resistance (Re)
Voice Coil Inductance (Le)2.1mH
Mechanical Q (Qms)12.8
Electromagnetic Q (Qes)0.65
Total Q (Qts)0.62
Compliance Equivalent Volume (Vas)2.4ft³
BL Product (BL)10.35T·m
Maximum Linear Excursion (Xmax)4.7mm
Cone MaterialPoly Composite
Surround MaterialFoam
Overall Outside Diameter10.75"
Baffle Cutout Diameter9.25"
Depth5"
# Mounting Holes6
Sealed Volume0.75ft³
Sealed F343Hz
Vented Volume1.25ft³
Vented F322Hz
    MONSTER DEAL
    OF THE WEEK
    $189.00 EACH
    SAVE 21%
    Dayton Audio SPA250DSP 250W Subwoofer Plate Amplifier with DSP
