Knock-Down 2x10" Baltic Birch Bass Guitar CabinetBuild your own custom 2 x 10" guitar or bass speaker cabinet with this CNC cut Baltic birch knock-down enclosure. Constructed of high quality 5/8" thick 11-ply Baltic birch, this rigid cabinet is extremely strong and can take all the use and abuse you can throw at it. For even more durability all of the joints are rabbeted or dadoed for maximum gluing surface area. This 1.9 cubic foot enclosure includes a slot port on the bottom of the baffle, with a tuning frequency of 47 Hz, for extended low frequency reproduction and output. In addition, the slot port acts as bracing on the bottom panel of the enclosure to keep this enclosure from walking around the stage when you hit that low E.
Customize the assembled enclosure to fit your style -- wrap it in carpet or vinyl, paint it, cover it in veneer, coat it in polyurethane, or even plaster it with stickers -- the possibilities are endless. The 9.125" driver cutouts are compatible with most popular bass and guitar speakers on the market, so load this with your favorite drivers and build your own version of a high dollar speaker cabinet for a fraction of the price.
Includes CNC-cut plywood knock-down panels. Assembly instructions are available for download in the "Manuals & Resources" section.
Specifications: • Internal volume: 1.90 cubic feet • Tuning frequency: 47 Hz • Driver cutout: 10.125" • Baffle recess: 1" • Dimensions: 13.75" H x 28" W x 12" D • Port dimensions: 2" H x 8" W x 7.875" L • Plywood: 0.625" thick, 11-ply Baltic birch.
