  • FaitalPRO 12FE330 12" Professional Woofer 8 Ohm
FaitalPRO
Part #294-1334
FaitalPRO
Part #294-1334
Model: 12FE330
The FaitalPRO 12FE330 12" Professional Woofer is a great choice when you need smooth response, high sensitivity and incredible bass response in average size ported or sealed enclosures.
  • Glass fiber reinforced paper cone for smooth natural response
  • High 94 dB sensitivity for incredible output potential
  • Half roll rubber surround for clean linear excursion
  • Above average 8.32mm Xmax for impactful low-end
Your Price: $155.00
3In Stock
Featuring a glass fiber reinforced paper cone, half-roll rubber surround and 250W program power handling, this woofer is ready to rock in a number of different applications. An excellent choice in a studio, small venue or even home audio environment.
BrandFaitalPRO
Model12FE330
Part Number294-1334
UPC848864074689
Weight9.65
Nominal Diameter12"
Bolt Circle Diameter11.57
Power Handling (RMS)250 Watts
Power Handling (MAX)500 Watts
Frequency Response30 to 3000Hz
Sensitivity94dB 2.83V/1m
Voice Coil Diameter2.05"
Resonant Frequency (Fs)33Hz
DC Resistance (Re)5.3Ω
Voice Coil Inductance (Le)1.1mH
Mechanical Q (Qms)7
Electromagnetic Q (Qes)0.48
Total Q (Qts)0.45
Compliance Equivalent Volume (Vas)5.18ft³
Mechanical Compliance of Suspension (Cms)0.31mm/N
BL Product (BL)13T·m
Diaphragm Mass Inc. Airload (Mms)74.2g
Maximum Linear Excursion (Xmax)8.32mm
Surface Area of Cone (Sd)579cm²
Cone MaterialPaper
Voice Coil Wire MaterialCCA
Voice Coil FormerFiberglass
Overall Outside Diameter12.24"
Baffle Cutout Diameter11.18"
Depth5.24"
Sealed Volume1.82ft³
Sealed F362.75Hz
Vented Volume5.852ft³
Vented F331.5Hz
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
