  • Eminence Alpha 3-8 3" Full-Range Driver 8 Ohm
Eminence Speaker
Part #290-4014
Eminence Speaker
Part #290-4014
Model: Alpha 3-8
The Alpha 3-8 from Eminence Loudspeakers will allow you to pack big performance into small spaces. Perfectly suited for portable speaker systems, column, and line array applications this is a truly versatile full range driver.
  • True full range response with useful output up to 20,000 Hz
  • Unique internal neodymium magnet improves efficiency and high frequency response
  • Impressive efficiency for a driver this small
  • Poly coated paper cone produces smooth response and resists water
Your Price: $24.99
MSRP: $49.99
Save $25.00 (50%)
Order in the next 5 hr 1 min to ship today. Details
13In Stock
Eminence's Alpha 3-8 3" is a versatile compact full-range driver perfectly suited for tight fitting pro audio line array and column array applications. An 8.3 oz ferrite magnet used in conjunction with an internal neodymium bucking magnet increases the sensitivity and extends the response out to 20kHz. The highly pressed cone sandwiches paper with a layer of water-resistant polypropylene for increased stiffness and lower distortion. With such high efficiency and wide frequency response this driver would also be an excellent choice for small portable speaker systems.
BrandEminence Speaker
ModelAlpha 3-8
Part Number290-4014
UPC876358003877
Weight1.1
Nominal Diameter3"
Bolt Circle Diameter3.63
Power Handling (RMS)30 Watts
Power Handling (MAX)60 Watts
Frequency Response150 to 20,000Hz
Sensitivity88.6dB 2.83V/1m
Voice Coil Diameter0.79"
Resonant Frequency (Fs)118Hz
DC Resistance (Re)5.12Ω
Voice Coil Inductance (Le)0.11mH
Mechanical Q (Qms)7.94
Electromagnetic Q (Qes)0.53
Total Q (Qts)0.5
Compliance Equivalent Volume (Vas)0.03ft³
Mechanical Compliance of Suspension (Cms)0.84mm/N
BL Product (BL)3.93T·m
Diaphragm Mass Inc. Airload (Mms)2g
Maximum Linear Excursion (Xmax)2.4mm
Surface Area of Cone (Sd)28.6cm²
Cone MaterialPoly
Overall Outside Diameter3.98"
Baffle Cutout Diameter3.04"
Depth1.76"
Sealed Volume0.04ft³
Sealed F3220Hz
Vented Volume0.06ft³
Vented F390Hz
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
