DataComm 45-0017-WH Split Plate with Flexible Opening - White
DataComm Electronics
Part #261-548
Part #261-548
Model: 45-0017-WH
The DataComm split plate with flexible opening enables audio/video wires and cables to pass through the wall behind your TV, amplifier, or other devices. Two interlocking halves combine to make a single bulk cable wall plate.
- An easy retrofit: the plate splits into two wire-encircling sections
- Run up to six A/V cables through your wall
- Both halves of the plate create a virtually seamless design
- Quick and easy to install
- Perfect for eliminating connections at the wall
- Low profile design easily fits behind flat screen TVs
- Fits standard single-gang low voltage mounting ring
