DataComm 20-4503-WH Standard Wall Plate with HDMI Connector and Pigtail White
DataComm Electronics
Part #261-571
Part #261-571
Model: 20-4503-WH
The DataComm 20-4503-WH standard wall plate HDMI connector with built-in pigtail cable is the perfect solution to connecting all of your HDMI products behind your walls to give you a clean, organized look.
- Compatible with high speed 1.4 HDMI cords
- Securely attach HDMI cables to the front and back
- Decor insert can be removed for use in multi-gang applications
