  • Celestion TF0818 8" Professional Speaker 150W
Celestion
Part #294-2060
Celestion
Part #294-2060
Model: TF0818
The Celestion TF0818 8" speaker serves equally well as a woofer or dedicated midrange component when used in pro loudspeaker systems.
  • 94 dB sensitivity and 100 watts RMS power handling
  • 1.75" high temperature copper voice coil wound on polyimide former for increased reliability
  • Achieves optimal performance in compact enclosures
  • Exceptional performance through bass and midrange
  • Ideal for 2-way systems
Your Price: $69.50
MSRP: $104.25
Save $34.75 (33%)
6In Stock
The versatile and efficient Celestion TF0818 8" driver offers excellent performance when used in bass and dedicated midrange applications. Its 1.75" copper voice coil is set onto a polyimide former, which assures good long term resistance to the detrimental effects of extreme high temperatures. A double half-roll cone surround, combined with an optimized Kevlar-loaded paper cone, ensure the speaker's frequency response is smooth and extended. The large 31 oz. ceramic ferrite magnet provides plenty of motor strength.
BrandCelestion
ModelTF0818
Part Number294-2060
UPC739894533249
Weight5.5
Nominal Diameter8"
Power Handling (RMS)100 Watts
Power Handling (MAX)200 Watts
Frequency Response70 to 6,000Hz
Sensitivity94dB 2.83V/1m
Voice Coil Diameter1.75"
Resonant Frequency (Fs)100Hz
DC Resistance (Re)6.72Ω
Voice Coil Inductance (Le)0.75mH
Mechanical Q (Qms)3.31
Electromagnetic Q (Qes)0.49
Total Q (Qts)0.43
Compliance Equivalent Volume (Vas)0.33ft³
BL Product (BL)12.95T·m
Diaphragm Mass Inc. Airload (Mms)19.57g
Maximum Linear Excursion (Xmax)3.5mm
Surface Area of Cone (Sd)226.8cm²
Cone MaterialPaper / Kevlar
Surround MaterialCloth
Overall Outside Diameter8.19"
Baffle Cutout Diameter7.2"
Depth3.54"
Sealed Volume0.3ft³
Sealed F3188.4Hz
Vented Volume0.6ft³
Vented F386.9Hz
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
