BUYOUT BL-409 Plastic Horn Waveguide
- ABS construction
- Mounting flange for 2-bolt 1" drivers
- 40° x 60° dispersion pattern for wide coverage area
- Useable to 500 Hz
For over 30 years, B-52 has manufactured Pro Audio gear in California using only high-quality components. We recently acquired a massive shipment of audio speakers and other gear from B-52 during a warehouse clean-out. This huge buyout of woofers, compression drivers, horns, crossover components and cabinet hardware is now available at Parts Express for a fraction of what you would normally pay. Many drivers in this factory buyout are New Old Stock (NOS) from famous brands and could be considered vintage. Like the B-52 bomber, this factory buyout travels the globe and includes drivers manufactured by famous brands around the world in places like the UK, USA, Denmark and Brazil. This is a one-time buyout opportunity so quantities are limited.
Specifications: • Lowest recommended crossover frequency: 500 Hz • Nominal coverage: 40° H x 60° W • Dimensions: 11" H x 14-1/2" W x 8" D.
Product Details | |
Brand | Factory Buyouts |
Model | BL-409 |
Part Number | 299-2327 |
UPC | 848864052243 |
Unit of Measure | Each |
Weight | 2.3 |
Product Specifications | |
Construction | ABS |
Entry / Throat Diameter | 1" |
Mounting Type | 2-Bolt |
