  • 5 GHz 1080p Wireless HDMI Extender Transmitter and Four Receivers System 100m/328 ft.
Part #184-455
Part #184-455
Extend your HDMI HD signal wirelessly up to 328 ft. with this wireless transmit/receiver set. The set also has a built-in IR extender for remotely controlling the source at the receiver's location.
  • Simple plug and play, no software needed
  • Extends HDMI signal up to 328 ft. for convenience
  • Compliant with HDCP 1.3
  • Supports LPCM and other uncompressed audio
  • Audio sampling rate up to 48 kHz
  • Includes five IR extender cables that plug into the receiver and transmitters for controlling the source at the displays location
  • FCC, CE, RoHS certified
Your Price: $509.98
12In Stock
This wireless HDMI extender lets you extend HDMI audio/video signal up to 328 ft. via 5 GHz band, with very low latency. It's ideal for point to point signal extension situations that require high quality HDMI video in a location where running cable is difficult or impossible. A built-in inferred extender enables the user to remotely control the source with its original remote at the display's location. This kit includes an extender transmitter, four receivers, and five short IR cables that enable you to keep the five wireless boxes out of sight.
Note: When adding extra receivers, follow the troubleshooting guide line-by-line. You must use the included 3.5 mm cable. Do not connect power to the transmitter or receiver until all other cables are attached. You must press reset on the transmitter and receiver exactly at the same time when instructed. If any of the four receivers stop receiving, power cycle it. Allow two to three minutes after pairing or power cycling for the picture to appear.
Specifications: • Transmit frequency: 5 GHz • Wireless extension distance without obstruction: 328 ft. (100m) • Power requirements: 5 VDC @ 1A • Output resolution: Up to 1080p 60 Hz, depending on input resolution • Audio sampling rate: Up to 48 kHz • IR frequency range 20 - 60,000 Hz • Chassis material: Metal • Dimensions: 5.12" W x 3.94" D x 1" H (130 x 100 x 25.5 mm).
Part Number184-455
UPC848864066660
Weight6.1
MONSTER DEAL
OF THE WEEK
$59.99 EACH
SAVE $25
ProMounts SAM Ultra Slim 30"-60" Articulating TV Wall Mount
