  • Dayton Audio A400 2x200 Watts Class AB Stereo Power Amplifier
Dayton AudioPart # 300-810
Model: A400
The Dayton Audio A400 Amplifier delivers high-quality sound through superior performance and great value, offering up to 300 watts per channel at 4 ohms, with the ability to deliver 500 watts RMS when bridged. It ensures cool, quiet operation during lengthy listening sessions and provides flexible connections, supporting both RCA and XLR through gold-plated ports, while allowing complex configurations with multiple amplifiers. Integrating seamlessly into any home audio setup with its brushed aluminum faceplate and oversized knob, it offers universal compatibility, syncs power with other equipment, and can disable the front LED for distraction-free viewing, making it a remarkable upgrade to any sound system.
  • Ability to deliver up to 300W RMS per channel or up to 500W RMS when bridged
  • Class AB topology for cleaner, crisper sound with remarkably low distortion
  • Easily switch between balanced and unbalanced inputs supporting both RCA and XLR
  • 12V trigger inputs and outputs compatible with all power triggering systems
  • Universal compatibility operating at either 115 or 220 volts
  • Unique symmetrical circuit design and transformer placement for balanced audio
  • Heavy-duty gold-plated connections and chainable inputs for complex configurations
Your Price: $599.00
MSRP: $1,168.99
Save $569.99 (49%)
We'll send you an email when Dayton Audio A400 2x200 Watts Class AB Stereo Power Amplifier is back in stock or available for preorder.
Order in the next 8 hr 23 min to ship today. Details
Experience true hi-end power in your entertainment system with our new A400 Amplifier. Seamlessly blending top-notch functionality and specs with great value, this piece is set to change the way you experience home audio.
The A400 Amplifier makes an immediate visual impact with its classic, yet contemporary aesthetics. Crafted with an emphasis on simplicity and elegance, it adds a touch of sophistication to any space. The faceplate, fashioned from brushed aluminum, and oversized knob commands respect in a 3U package.
Built with a well-ventilated chassis, the A400 Amplifier runs cool even during extensive listening sessions and the unique symmetrical circuit design, and transformer placement, enhances balance and consistency in your audio experience, because of this, no noisy fan is required.
The Class AB topology of the A400 provides a 100dB Signal-to-Noise Ratio for cleaner, crisper sound, with a remarkably low %0.05 THD+N while providing up to 300W RMS per channel at 4 Ohms (600W Peak). For higher-powered use, the A400 can be bridged with the ability to deliver 500W RMS mono at 8ohms with %0.01 THD+N.
Versatile and professional, the A400 amplifier is designed to meet all your audio needs with ease. Building upon its exceptional performance, this amplifier offers a seamless switch between balanced and unbalanced inputs, accommodating both RCA and XLR connections effortlessly. Whether you prefer the convenience of RCA cables or the enhanced audio quality of XLR cables, the A400 has you covered.
12V Trigger inputs and outputs allow seamless power management in your home audio system. Our device is compatible across triggering systems, so you can easily integrate it without complications. We know bright lights can distract, so we gave full control over the front LED power via a switch on the rear for undistracted enjoyment.
The A400 Amplifier combines functional design and superior sound quality in a straightforward and reliable package. Its advanced features, paired with a clean aesthetic, ensure it blends seamlessly into any home audio setup. Explore the A400, and experience the difference that a well-crafted amplifier can make in your audio journey.
For more detailed specifications, please see the provided AudioPrecision documents here or in the Manual and Resources tab
  • 200WPC RMS @4Ω / FTC 20 Hz- 20 kHz / 0.01% THD
  • 165WPC RMS @8Ω / FTC 20 Hz- 20 kHz / 0.05% THD
  • 300WPC RMS @4Ω / FTC 20 Hz- 20 kHz / 0.05% THD
  • 500W RMS @8Ω / Bridged 20Hz-20kHz/ 0.01% THD
  • Frequency Response: 15Hz-20,000Hz
  • Input Sensitivity: 0.43V
  • Minimum Speaker Impedance: 4 Ohm (8 Ohm Bridged)
  • SNR: 100 dB (A-weighted)
  • Dimensions: 17" x 16-11/16" x 5-3/16"
  • Weight: 41.5 lbs.
ModelA400
Part Number300-810
UPC848791009518
Weight54.65
Power (RMS/Channel 8 ohms)251 - 500 Watts
Weight Range40 to 49 lbs.
