120-015_ALT_0
4.5 VDC 500mA AC Adapter
universal AC adapter input voltage 120 VAC, output voltage is 4.5 VDC with 500 mA current capacity. Requires purchase of plug tip for operation (sold separately) -- simply choose size/style for your application.
  • Input voltage: 120 VAC
  • Output voltage: 4.5 VDC @ 500 mA
  • Requires purchase of plug tip for operation (sold separately)
  • 6 ft. cord length
  • UL approved
120-015
Weight: 0.65 lbs.
IN STOCK
$5.95
Buy 10-up$5.50
Part # 120-015
This universal adapter allows the user to choose the plug size/style for their particular application. Voltage polarity can be easily changed by reversing the plug. Adapter has an input voltage of 120 VAC, 6 ft. cord length and is UL approved. Output voltage is 4.5 VDC with 500 mA current capacity. Requires purchase of plug tip for operation (sold separately) -- simply choose size/style for your application.
  • DC Output Voltage4.5V
  • Current Capacity500 mA
  • Center/Tip PolarityReversible
  • Plug SizeNo Tip
  • Input Voltage110~120 VAC VAC
  • BrandParts Express
  • Part Number120-015
  • UPC844632025662
  • Product CategoryAC/DC Power Adapters
    (5 Reviews)
  • Weight0.65 lbs.
View similar products to the 4.5 VDC 500mA AC Adapter
in the AC/DC Power Adapters product category.
4.5 VDC 500mA AC Adapter is rated 4.8 out of 5 by 5.
Rated 4 out of 5 by from Solid little adapter with minor issuesThese are typical of many small "wall warts" in that they don't regulate well until you have some load on them. My application for this was to replace the batteries is a small decorative LED string. Open circuit, the voltage was ~6 volts, lightly loaded with the string of LED's it's ~5.2V. If the regulated voltage is important to you with very light loads, you could use a shunt resistor to add enough load to get the unit into regulation, or spend more money on another adapter with better regulation. But, for the price (and most applications) they are just fine.
Date published: 2014-03-19
Rated 5 out of 5 by from perfect ac adapter for eton G8 radioThe 6vdc adapter which was designed for the G8 radio didn't work- produced an AC buzz. The 4.5vdc adapter was a perfect match and the radio works great. Hope to place another order with parts express in the future.
Date published: 2013-09-19
Rated 5 out of 5 by from Lucky to have found this producedThis Is going to save on battery use. Who's not going to love that. Great
Date published: 2011-02-17
Rated 5 out of 5 by from GREAT PRODUCTWORKS GREAT FOR XMAS STUFF
Rated 5 out of 5 by from Met ExpectationsI was warry of product because of similar prices at Radio Shack $26.00 & Battery Plus $17.00. Upon delivery, my DC voltmeter showed 7.2 V with no load. However, I took a chance and hooked up to load, and has worked perfectly for several days on holloween display requiring 4.5 VDC & 500ma.
Customer projects that include: 4.5 VDC 500mA AC Adapter
Related Products
Customers Also Bought
Host-Name:ZNODE2
